sfbayjay
- January 22, 2008
- Cleveland-ish, OH
- 2002 XLT SOHC 4L V6
2002 XLT 4.0L V6
BACKGROUND:
AC stopped working over the winter (worked last fall, but not very cold). Compressor not engaging when AC active at dash. Checked electrical connections at compressor. No voltage at compressor electrical connector when AC switch on. Disconnected AC cycling switch (aka "low pressure switch"), jumped the connector, turned on AC at dash, and compressor immediately kicked on. This suggests either low refrigerant charge or faulty AC cycling switch.
Rented manifold gauge set from AutoZone, along with a vacuum pump.
Connected gauges on high and low sides. Pressures read virtually zero on both gages (made sure to check connectors and ensure screw-down valves on high- and low-side connectors were screwed down). Suggests compressor not starting because system pressure below minimum.
Suspecting leak, decided to try and pull a vacuum on the system. Connected vacuum pump to yellow manifold hose, turned on vac pump, then opened both high- and low-side valves on gage set. Let pump run for 40 minutes. Gage on low-side hit a minimum of -25" Hg after about 20 mins and stayed there. High side gage pegged at minimum (neg. pressure).
Closed both valves on gauge set. Turned off vacuum pump. Let system sit for 1 hour. No change at either manifold gauge - same readings (-25" Hg on low side, and "pegged" at low end on high side).
This suggests no leak (where did refrigerant go?) or VERY small leak. System hasn't been serviced/recharged in about 10 years, and wasn't blowing too cold last year when clutch was still engaging.
QUESTIONS (any help appreciated!):
1. At this point, can I assume system is "empty" of refrigerant (since system pressure measured at 0 on manifold gauges), or might there still be some small amount of refrigerant in the system? I know how much R134a is supposed to be in the system when it's "full" (56 oz, since I have aux climate control), but am I starting from empty?
3. If there may be some residual refrigerant in the system, should I just gradually refill until I hit "correct" pressures on the high and low sides (as opposed to just adding 56 oz)? Are the "generic" charts that show high- and low-side pressures at different ambient temperatures suitable for doing this, or is there a specific temp/pressure chart for Ford and/or Explorers?
4. Since I clearly have a small leak somewhere, any concerns re. using a refrigerant that is pre-mixed with a dye and/or with some "stop leak" stuff?
5. I never opened the system, and I haven't replaced any components, so I'm not really worried about adding makeup oil, right?
Thanks for any help - trying to do this as "right" as possible on a budget and considering truck is getting old...
BACKGROUND:
