quick ? about fog light wiring | Ford Explorer - Ford Ranger Forums - Serious Explorations
I did the parking light fog light mod on my 95x. I have a second set of fogs that I have wired to the battery right now. I was wondering if I can hook the + wire for the fogs to my fog light relay. I don't think that this should put an over load on the relay. Any advice?
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
use a splice off the factory fog to signal the aftermarket relay? that is fine.
R
rydinhigh
Hey Alec, I am a little confused. Lemme try to help you try to help me. Basically what I want to know is if I can use the stock fog lamp relay to wire my new fog lights into and have my stock and aftermarket fogs run off that one stock relay, all in the same time having the stock fog lamp relay get power from my parking lights. I hope this helps. As always thanks for your help.
Bill Kemp
Elite Moderator Emeritus
Moderator Emeritus
Greenville, MI
98 Mountaineer 5.0 AWD
If the question is: Can the stock relay operate both the stock fogs and the pilots? The answer is probably for a while. I would think Ford didnt oversize the relay in anticapation of additional lights. So it wont last long.
If you do as Alec suggested and use the stock relay to power the relay for the Pilot lights you will have no problems. Not useing a relay in any light application is asking for trouble and you usually dont get all the light that a light set is capable of without a relay.
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
Definately wire the new lamps with their own power source and own relay. You can do as I suggested and use the stock wiring as a switch, or install a separate switch and run the new ones totally independent. Do not try to run the new fogs off the old wiring (for power or relay).
Good luck!
