FlyinBarney
- February 5, 2018
- Mesa, AZ
- 97 Explorer Sport
Hey all,
I am trying to figure out which springs I want to use, so where better to ask than here!? Don't roast me with the "Use the search" function just yet.
I read through many of the threads, but most are old, and I want to make sure all the info is still valid.
My rig is a 1997 Sport 2DR 2WD with a sagging MONO Leaf on the driver's side. Obviously it makes sense to replace them with a 4-door style pack. I'm considering a set of used Deavers G50 because we go play in the desert. If I decide not spend the money, then I'll just do a set from SD Spring.
One thing that I noticed is that all the replacements are 2 1/2" wide springs, but the mono-leaf is a 3" wide spring and narrowed to 2 1/2" at the eyelets. I would assume that the bottom spring plate (Where the shock attaches) has 3" wide holes for the U-Bolts.
Does anything need to be addressed on this? Different U-Bolts, plate, etc..?
