Rack & pinion removal help is needed. | Ford Explorer Forums
spike6932
newport,ky
2000 limited
2000 explorer steering rack removal ,reinstall . do i need to lower front diff. or raise engine some? thanks
welcome
Did you mean to type that into the search bar? :dunno:
you may need to lift the engine, but shouldn't need to touch the diff housing.
You definitely need to lift the engine if you have the 5.0 V8.
One or two threads I've read with the 4.0, it was not necessary.
