97explorerltd
- April 26, 2008
After replaceing the water pump due to a leak the rad let go after the rad was replaced the thermostat housing cracked. All this happened in the span of 3 weeks, now that there are no visible leaks a new problem has popped up and that is the upper & lower rad hoses collapse after the engine cools down. This truck has never been over heated so I don't suspect a block or head crack. Is there something I might be missing?
