Radar detector tips/ suggestions?
Alan in AZ
Phoenix AZ
2013 Limited 4WD
You can tap right into the 12+ wire going to the mirror. This is switched with ignition so that you don't have to run a 12v+ wire all the way back to the fuse block.
Thats good to know - my 2013 is buing built so I get to try it out in a few weeks.
Alan
2k11Explorer
Radartest.com
Valintine one is older technology. Read up on it for yourself.
Alan in AZ
Phoenix AZ
2013 Limited 4WD
Be careful what you read - there is a lot of very biassed junk out there...
I can assure you that they actually still work well. There are newer features on other models including many with GPS based features. However most Valentine One owners find the directional arrows & hit counters to be an interface feature they don't want to live without...
Valentine does continue to improve the same design (you can send your unit in for upgrades).
It may in fact be time for a major upgrade - but that doesn't mean the current version is totally obsolete nor that is isn't still one of the best detectors available
Alan
Matt228
Ottawa, IL
2013 Green Gem Limited
Powering radar detector with mirror
The only other thread I can find on here is in the stock forum so I thought I'd post it here. (http://www.explorerforum.com/forums/showthread.php?t=316759)
Here is what I have: http://store.blendmount.com/mirrort...se-ford-explorer-p474.aspx?ShowQuestions=True
Here is where it plugs in:
The other thread tells me to plug the red wire into where the top left wire is. The black to go nto where the bottom right one is.
How do I plug these into spots where wires are already at?
JarHead1833
PA
2013 Explorer Sport
Do they mean "tap" into those wires?
Matt228
Ottawa, IL
Not sure. I'm a bit of an idiot when it come to electrical.
Kfoss1
Tampa Fla.
2013 Explorer Limited
The harness has tiny little spades that you push in next to where the existing wires go. It,s a pretty tight fit, other wise you have to pop off the cover on the windshield and splice them in. I saw a tutorial on youtube explaining it pretty good. Hope that helps.
Matt228
Ottawa, IL
Wow, that's gonna be tight but I'll give it another try.
Kfoss1
Tampa Fla.
Yea it is, I used needle nose pliers and gently wiggled them in. I couldn,t get them in all the way but it works.
Matt228
Ottawa, IL
Looks like I'll be splicing into the existing wires.
I tried putting them in with needle nose and broke off the tab on the end. My RadioShack didn't have anything smaller either.
AGray34
2013 Explorer Sport
Radar hardwire power sources...
I am new here, just purchased a 13 Explorer sport.
I am trying to hard wire my V1 in. I bought the mirror tap, however it just does not seem to stay too secure in the terminals. I would prefer to tap and splice direct to a 12V power.
Does anyone have a wire to recommend? I was just going to pull down the head liner and tap into the 12V acc wire and ground that go to the mirror.
Any other suggestions would be appreciated...
TIA
joshdhat
Dallas, Tx
13 Explorer Limited
i tapped into the black and black and yellow. from the plug coming from my rear view.
Rudsther2435
Yuma, AZ
2013 Ford Explorer XLT
This is the most appropriate spot: Accessory purple/green + ignition switch, black 7 pin plug, pin 6
Brett19648
14 EX Sport, 10 Jetta TDI
new EX Sport
Just picked up my EX Sport.
Was going to hardwire my radar detector. Anyone have any recommendations on where/what wire to tap into?
I saw a very short walkthrough on youtube of a guy using the power supply going to the rearview mirror but it was somewhat vague.
WOLFexplorer
Massachusetts
2011 Explorer Limited
everyone should get the app waze on your phone. you can spot a cop miles away
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
[B said:
Brett19648[/B];3206504]Just picked up my EX Sport.
Welcome to the Forum Brett19648.:wavey:
As I mentioned in my PM, I have moved your post to this existing one on the same topic. Perhaps you can find the info you are looking for here in the previous posts.
Good luck.
Red14Sport
Winter Park, FL
2014 Ford Explorer Sport
Valentine 1 for me. Have used it for over 10 years and "knock on wood" never had a ticket. It has saved my butt many times! If you read all about it on the Valentine 1 page and research the forums, very few people dislike them.
bigmoose15
Cambridge, MA
2013 ExSport
I Agree. I just started using this. Around boston there are so many users. I rarely get the opportunity to even report a car in the breakdown lane since someone beat me to it.
I stopped using my 8500 X50 a while ago.
CobraJohn
Magnolia, Texas
2014 Explorer Sport
I opted for Escorts "Redline" for its superior range coupled with their Livewire system for Social Radar Support via my IPhone.
thestumper
Pittsburgh, PA
2013 Ford Explorer Sport
It all depends on how you use it. I've been using a Valentine 1 for over 20 years and and have 3 tickets in that span. 2 were on a motorcycle where I didn't have it with me, and the other was VASCAR (no radar zone - PA is weird with radar restrictions...). On the interstate, my strategy is to find some other idiot who wants to tempt fate and then tail him about a quarter mile back. That should give me enough time to react, even in the case of instant-on Ka (or in some cases laser). If you're fool enough to lead that pack at break neck speeds, eventually your number will come up regardless of how good your detector is.
The reality is that the police can write as many tickets as they want, all day long, and all the really need is VASCAR or K-band. They will get more than their fair share of stupid drivers with even the most mundane methods. Plus, Ka and Laser actually require WORK. The bands are narrow, and you generally have to point and shoot, and not suck. It's a skill, and who really wants to be bothered with that? I used to think the PA State Troopers were neanderthals the way they standardized on old fashioned K-band, but now I see the genius of it. Sit back in the cruiser, relax, and wait for the idiots to fly by. Even better, just compute times between toll booths on toll roads and hand out the tickets at your leisure. I'm pretty sure you could train a monkey to do that job. Either way, you can still rung up plenty of numbers without breaking the bank.
Aircraft enforcement is a sad joke. Any public official who tries to justify the budget for such and operation should be strung up at city hall IMO. How much does it cost to fly a plane per hour? A helicopter? How many tickets do you need to write to cover that absurdity??? :eek:
Please don't misunderstand my rant. Cops do a hard, dangerous job that I don't have the guts or patience to do. Traffic enforcement, unfortunately, is a necessary evil - it's a part of the job and they are required to do it. It's not even safe - we've all seen the videos of these guys getting mowed down during a "routine" stop by some clueless, half baked imbecile. That said, from a revenue perspective, it's a game. Play smart, and if you get caught, it pays to play nice. :)
