Nitroheli
- June 5, 2020
- W.Palm Beach
- 2013 Ford Explorer XLT
Have a 2013 Ford Explorer XLT. Drove through some flooded streets due to heavy rain.
Now when I turn the A/C on, the two electric fans on the condenser/radiator cycle on high for 15sec. turn off for 30sec and then repeat this cycle. This only occurs when the vehicle is going slow or stopped. I've swapped the high and low fan relays
and also tried pulling the #2 High Speed Relay. The A/C put's out ice cold air so the sys. pressures should be
fine, and the engine temp is always normal. Was reading somewhere maybe the pressure transducer might be the culprit. Need help with this, not sure what to do next.
