Radiator replacement. | Ford Explorer - Ford Ranger Forums - Serious Explorations
my ford
Hernando,ms
I have a 2006 Ford Explorer 4.0v6 -- the radiator is leaking and I am going to replace it myself -- does any one know how to refill the transmission fluid that is lost when lines are disconnected from the radiator? Thank you
1Aauto
EF Vendor
mass
92 explorer
HI, once you have everything hooked up. Start the truck and refill the tranny through the dipstick tube.
Once it's warm shift through all the gears a few times and then recheck the fluid level.
swetrid
Reading Pa
1999 Eddie Bauer
There is no dipstick tube. Ford has a special tool to fill but you can rig a vacuum hose on top of a bottle of trans fluid and squeeze it in there until you get proper level.
1Aauto
EF Vendor
mass
92 explorer
scratching head...lol, is it a V6 or V8, this is a new one for me. I thought pretty much all vehicles with an automatic tranny had a dipstick tube to check the fluid level.
swetrid
Reading Pa
1999 Eddie Bauer
Alot of cars these days don't have dipsticks. The theory behind that is to keep people from adding incorrect fluid and ruining the trans.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Welcome to this forum! I've moved your thread into the stock 2006-2010 section. Check the sticky thread on the top of the transmission section called the 5R55W fluid fill for more information. There are aftermarket dipstick kits available.
waskly
Crooklyn NY!
since 02 no explorer has a dipstick tube.
waskly
Crooklyn NY!
also keeps dirt out of the trans :)
no way for it to get in.
nh5
Long Island
'06 Explorer XLT V6
What did you guys use to disconnect the trans lines on the radiator? I know ford lists a specific tool but doubt everyone has it. Also is there multiple different types on connectors that are shipping on the replacement radiators? I hope not.
