davetib
- February 11, 2007
- 2003 Explorer
Hello everyone,
Here's the backstory. 2003 8 cyl 4x4 Explorer. Had a parasitic drain on the battery and found the culprit was Fuse #28 - Radio (Start) / DVD (Start). Pulling 500mA with fuse in and 20mA with fuse out.
So I pull the wiring harness off DVD. Nope, not the problem
Did the same with the amp and the radio. Pulled all plugs from the radio and still pulling 500mA.
So I thought maybe it was the thingy that tells the radio to turn off after 10 minutes. So plugged everything back in and tested. Radio turned off in 10 minutes just like it's supposed to. Now I'm perplexed.
Everything else in the vehicle is working perfectly. If I pull fuse 28, all is right with the world, but no radio.
Anyone have a clue what might be the issue here?
Thanks,
Dave
Thanks,
Dave
