dannytech_lt
- March 27, 2012
- Union nj
- 2000 Eddie Bauer 5.0
How are there no pictures at all..
Sent my board into the "save my sanity" place, it lasted 2 months and has now died again. For the PITA that removing the radio is I'm just going to install a new aftermarket unit and be done with it. Sure they'll redo it again but don't want to have to pull it and send it back every couple of months.
Funny, what incompetent person did you allow to "fix" your radio? I had mine done about seven years ago, and it's still going fine.
The proper repair is to replace the display board, not to solder things on the original defective board. The radio is a great unit, besides the original display board.
Replace the board, don't bash the radio.
I resoldered every component I could on the boards in two radios and they both have been going strong for what is probably at least 5 years now. Replacement is not necessary IMO, a quality repair is all that is needed.I used a solder sucker syringe, copper solder soaker braid, and some quality solder. I would remove the solder at a joint and then resolder, one by one until I did the whole board. It didn't take all that long to do and was sucessfull.
I am guessing the companies who fix these radios just solder until they start working, but it is only a matter of time until another joint fails.
Actually I would use Trevor at Pacific Audio http://home.comcast.net/~pacificaudiotech/
He fixed mine quick and for $50 a while back.
That was the smartest way I can think to fix this problem.
mikeh
Trever (or Mike) can be contacted at sayko4@aol.com
Quote: The repair cost is $45.00 plus shipping (you choose waht method).
Turn around is 1 to 2 days max.
Pack the radio well especially the face plate and volume knob areas...don't let radio bounce around.
I will repair the radio, invoice thru paypal (if you like).
check, m.o., or paypal is fine.
I warrant the display repair for as long as you own the radio. End Quote.
where is he located
"The repair cost is $45.00 plus shipping (you choose waht method).
I warrant the display repair for as long as you own the radio. "
he's in South Carolina.
Mike Harrington
304 Hartin Blvd.
Summerville,SC 29483
I believe you need to pay the return shipping and insurance is up to you.
thanks it worked when i hit rumble strips for about 2 minutes what is the rds in these radios
