jgilbs
- October 29, 2002
- Naperville, IL(home)/Iowa City, IA(school)
- 92 Eddie Bauer
Whenever I take a sharp corner I hear a loud THUNK, and it never fails to scare the **** out of me and my passengers. I did some searching and have a high index of suspicion that the Radius Arm bushings are bad. I went to replace these but found a MUCH more serious problem. My passenger side rotor was only being held on by 3 bolts! The last time I had work done (I had a new rim mounted on my tire) the Firestone(go figure) I brought it to COMPLETLEY crossthreaded EVERY lugnut! :fire: 2 of the lugs had shorn off and were just hanging loose. I also observed a TON of metallic dust inside the beauty cap. Today I went to the Firestone and confronted the manager about the problem, and he told me to have it towed in and they would take a look at it. He called me back and confirmed it was their fault and agreed to replace the rotor at no charge. He told me pads were 90% used (once again they are pretty new, but seeing as how I drive my car HARD and they were pretty cheap pads I wasn't going to argue the point too much) He advised that I should have the drivers side rotor turned (since the pass was being replaced) and get new pads for $80. I told him to just turn the rotors and I would take care of pads, since I was going to put ceramics on there anyway. So now when I get my car back I still need to replace the RA bushings and I have a few questions:
First, my jack and jackstands cant lift the car as high as I would like to do this job. Even with jackstands on the frame as high as I can get the car(I do have clearance to get under it) the tires still rest on the ground. Can I just remove the tires so that the suspension doesnt have any pressure on it? I would put jackstands under the frame behind the RA frame bracket, and use a jack under the axle to lift the tire high enough to remove the tire, Would this work?
Also my steering has always been pretty "loose", will replacing the RA bushings help this? I have heard that there is an adjusting screw for the steering system, where is it so I can try to fix it?
When reinstalling the RA nut, can I just use some Blue locktite and tighten it as tight as I can? I dont have a torque wrench and I dont think I'll be able to hit 100 ft-lbs without air tools(judging by how hard it is to get off, but it might just be the rust thats keeping it on now)
I got bushings for both sides and one is black and one is red, but they both have the same part # stamped on the box. Is this right? Or did Napa screw up and give me the wrong part?
When I was driving the other day(before I found out about the rotor) I heard my drivers side making some noise while driving next to a wall that sounded like a bad bearing, but when I jacked up the car, I tried to move the tire back and forth and I couldnt feel any play. But I did on the pass side (but not sure if this is because of the bad lugs) How do I conclusively check for a bad bearing? Would my rotor have caused these noises?(as firestone claimed today when I talked to them)
thanks for the help, this site always helps me out of a jam.
