Rancho Suspension Question
Mrlee75
Arcadia, CA
98 5.0L AWD Eddie Bauer
I'm looking into getting Rancho RS 5000's for my 97 AWD v8 EB. Their site gives me 2 options, one for a 1-2.5" lift and one for stock height.
If i'm doing a 1.5"- 2" WAR-153 shackle and tt lift will the stock height rancho shock absorbers still work without issues?
I'd like to order them soon so I have time next week to put em on. I'd be running stock height for a while until I save up to get 31" tires then doing the tt and shackle.
Appreciate the help.
Paraphoe
Go big or go home
Willow Grove, PA
'97 XLT
You can run the stock height ones, yes.
2TimingTom
Location
Littleton, CO
Littleton, Colorado
'97 XLT
I ordered the longer ones and installed them when I did the AAL and TT. I got maybe the 1". They seem to be working just fine.
JungleSkunk Rancho Shock Question Modified 1995-2001 Explorers 19
D Rancho RS9000XL is only for stock SUV? Modified 1995-2001 Explorers 6
S Rancho 9000XL with TT and shackles? Modified 1995-2001 Explorers 1
Lacky01 Rancho Shocks? Modified 1995-2001 Explorers 16
J Rancho RS9000x shocks Modified 1995-2001 Explorers 5
parad1mg Monroe Sensatracs or Rancho RS5000? Modified 1995-2001 Explorers 11
C Anyone have Rancho's with a 2' lift? Modified 1995-2001 Explorers 11
K Rancho Shocks Modified 1995-2001 Explorers 8
UtahX Rancho RS5000 vs. Pro Comps ES9000 Modified 1995-2001 Explorers 0
M Rancho 9000 ????? Modified 1995-2001 Explorers 23
9 Rancho Pros/cons Modified 1995-2001 Explorers 5
F 99 Explorer 4WD 4" Suspension Lift Modified 1995-2001 Explorers 10
Cuco Timbren suspension Modified 1995-2001 Explorers 4
shucker1 Suspension Insulator Pad Modified 1995-2001 Explorers 8
D Lift kit or Suspension conversion?? Modified 1995-2001 Explorers 24
E Explorer suspension Modified 1995-2001 Explorers 8
U Rear Suspension Parts Missing? Modified 1995-2001 Explorers 5
A Suspension Help Modified 1995-2001 Explorers 3
M Thinking about doing something with rear suspension above and beyond! Modified 1995-2001 Explorers 38
9 2nd gen IFS to 1st gen suspension explorer front end swap Modified 1995-2001 Explorers 10
S 98 Explorer suspension questions Modified 1995-2001 Explorers 4
T 98 explorer suspension torque spec. Modified 1995-2001 Explorers 4
B Suspension overhaul and torsen install Modified 1995-2001 Explorers 3
W Suspension Questions - Spring Over Axel, Levelling Kit, SAS, Torsion Keys Modified 1995-2001 Explorers 4
R Suspension lift vs. Body lift Modified 1995-2001 Explorers 4
S Suspension options Modified 1995-2001 Explorers 0
S '98 Suspension lift help Modified 1995-2001 Explorers 4
D Compatible suspension lifts Modified 1995-2001 Explorers 3
T Suspension Upgrade Modified 1995-2001 Explorers 8
K 5.0L with a 5-speed transmission & lowered suspension. Modified 1995-2001 Explorers 8
G 4" Suspension Lift Kit or ? Modified 1995-2001 Explorers 12
B 2nd gen suspension lift Modified 1995-2001 Explorers 10
T Suspension/towing help/tips please! Modified 1995-2001 Explorers 15
S Gen 1 suspension swap? Modified 1995-2001 Explorers 10
J Suspension lift kit for 2001 Explorer XLS Modified 1995-2001 Explorers 1
H Rough Country Suspension Lift System Modified 1995-2001 Explorers 0
S 2000 ford explorer sport suspension and tires Modified 1995-2001 Explorers 5
D Suspension advice Modified 1995-2001 Explorers 2
D rear suspension lift options Modified 1995-2001 Explorers 2
R Will a Superlift 4" suspension lift work in a 2002 Sport? Modified 1995-2001 Explorers 13
R help. suspension trouble after replace suspension parts Modified 1995-2001 Explorers 6
M Suspension Dos and Don'ts Modified 1995-2001 Explorers 5
H suspension question Modified 1995-2001 Explorers 2
9 4 inch suspension lift Modified 1995-2001 Explorers 11
A ome suspension for 97 explorer Modified 1995-2001 Explorers 10
Mike's brother Too much rear axle/suspension sideways shift? Modified 1995-2001 Explorers 10
D Front Suspension Modified 1995-2001 Explorers 24
richy2kool Suspension --- suggestions Modified 1995-2001 Explorers 16
F Suspension Questions Modified 1995-2001 Explorers 0
S Rusted out frame and suspension Modified 1995-2001 Explorers 2
Similar threads
