Badassbanshee
- November 15, 2016
- Mount Clemens mi
- 98 ford explorer 4x4
Ok guys I have a 98 4.0 Explorer with 202k that has a horrible rattle/chattering noise upon initial startup and idle. After driving the truck for 5 to 10 minutes the rattle almost completly subsides at idle and can only be heard faintly around 2500 rpm or more. It isn't consistant with engine rpm and really only varies in intensity.
I have half assed probed around with a screwdriver in an effort to pin down the source of said rattle to no avail. I believe it is coming from the upper left side of the motor in the vicinity of the timing chain. I have read about the timing chain guide issues with this engine and suspect the noise is the chain rattling on the guides from either a tensioner failure or strech.
Only thing that I don't get is that the noise dosen't change with engine rpm. I am not opposed to changing the chain, tensioners and guides but would prefer not to on a guess. Was hoping some of you guys have ran into the same rattle/clatter and could confirm my suspensions of a timing system issue...
Thanks in advance!
Thanks in advance!
