BAStumm
- December 18, 2007
- 1996 Explorer XLT.
History: Had this vehicle for a little over a year. Last spring had the intake manifold gasket replaced due to a coolant leak. Vehicle had some missing problems then also. At that time only p0300 showed. Currently it shows these codes:
P0133, P0300, P0303, P1151
Info obtained via a mac tools et50 scanner. It also allowed a freeze frame while driving which provided some odd data (or I think it is):
Fuel Sys Stat B1=0 B2=0
Load: 65.09%
Coolant Temp: 88 C
S.T. Fuel Trim B1 0.77% B2 0.77%
L.T. Fuel Trim B1 -1.57% B2 -1.57% <------ ???
Engine 1888 RPM
Veh Speed: 87 km/h
I've also seen P0304 a few weeks ago but cyl 4 misfire hasn't returned in 3 weeks at least. No codes seen for cylinders other than 3 and occasionally 4. Arent these on seperate sides of the motor thus controls by different O2 Sensors? Odd...
P1151 is lack of HO2S-21 switch. indicates lean.
P0133 is O2 slow response bank 1 sensor 1
Is this the symptom of some other problem or is 02 and possibly coil pack the quick and easy fix? Plugs and wires are new as of May or so. Dirty MAF Sensor?
I have to go through emissions before New Years and I procrastinated on this... Any ideas?
Load: 65.09%
Coolant Temp: 88 C
Engine 1888 RPM
Veh Speed: 87 km/h
