ranger brush gaurd? | Ford Explorer Forums - Serious Explorations
ranger brush gaurd?
Anything will fit if you dont mind doing some fabrication. I bought a used brush guard as well for my 96 ex ($15 - all glavanized 0 rust).. I dont think the one your looking at will fit without some modifications. I had to cut the brackets off the brush guard and weld them back on about 1/2" from thier original location. Then cut two holes in the front of the frame rails to slide the brush guard into. Plus a little more welding and cutting. In the end it worked out perfect because I have a 3" body lift and I dont think I would have found a better fitting aftermarket part anyhow. At least not for $15.
