drdavis_ks
- August 7, 2006
- Kansas
- 99 Sport
My 99, 4.0 SOHC, Auto, 145,000mi, Sport had a rattle/knock. I read plenty on timing chain death and was preparing for a massive overhaul. Upon total failure, found it was the flexplate. I removed the starter and found I could turn the flywheel (flexplate) with my finger.
The symptoms were a metallic rattle (like a heat shield or something) but only under 1000rpm. Over 1000 rpm it was smooth and quiet...normal.
It was very subtle, more annoying than loud. I'm pretty good but I could not isolate the rattle beyond engine-passenger side. Even changed spark plug wires figuring knock...they needed changing anyway.
Other than that, it ran and drove normal, no CEL or codes thrown. Never overheated or delivered unusual gas mileage. Failure was without warning. Tried to start up from a stop light...motor rev'd up but old green wouldn't move, kind of buzzing and sawing sound, expensive sounding. A daily driver, it went about 3 weeks from 'first noticed' to 'won't move'.
Flex plate is $100-ish, book says 5.5 hours to R&R transmission.
SO...rattle/knock does not always indicate a timing chain/tensioner issue.
