Rattle noise in roof
geoffj981
I have a 2008 XLT. I'm noticing a rattle noise in the roof when driving. I'm assuming it's the air line that runs through the roof for the rear ac. Has anyone else noticed this in their explorer or know of a fix?
Joe Dirt
07 Camry
Are you still under full warranty? I'd take it back in- my uncle had a loose mounting screw in his roof, as the robot missed it's mark. They fixed it up for him, and bent (creased) the headliner in the process- and had to replace it on their dime...
TowingExplorer
Central MA
2006 Limited V8
What did the screw hold down?.. the roof rack?
R noise/rattle behind tachometer and speedomoter??? Stock 2006 -2010 Explorers 5
J Rattle noise at startup, 2000-3000rpm acceleration on '06 4.0L SOHC Explorer Stock 2006 -2010 Explorers 5
M Steering wheel click/rattle noise Stock 2006 -2010 Explorers 21
B Whistle/Rattle noise Stock 2006 -2010 Explorers 0
M 06 timing chain rattle Stock 2006 -2010 Explorers 5
doug625 Looking to buy a 4th gen. Do any 4.0s exist without the timing chain rattle? Stock 2006 -2010 Explorers 22
R Rattle/vibration coming from exhaust Stock 2006 -2010 Explorers 1
S AC Compressor Rattle at Idle Stock 2006 -2010 Explorers 9
J '06 LTD Rattle from rear end Stock 2006 -2010 Explorers 7
M Steering wheel rattle, resolved! Stock 2006 -2010 Explorers 1
B Engine Rattle Stock 2006 -2010 Explorers 4
T Front end rattle Stock 2006 -2010 Explorers 2
mgmgmg Rattle Stock 2006 -2010 Explorers 1
mgmgmg Rear passenger rattle Stock 2006 -2010 Explorers 10
J Passenger seat rattle? :( Stock 2006 -2010 Explorers 14
T Exhaust/manifold rattle on ext. warranty? Stock 2006 -2010 Explorers 4
B Annoying Door Rattle Stock 2006 -2010 Explorers 4
D Rear Hatch rattle Stock 2006 -2010 Explorers 3
P 1-2 second startup rattle Stock 2006 -2010 Explorers 11
KillerB74 2007 EB 4.6L 4x4 Front End Rattle Stock 2006 -2010 Explorers 3
T Engine bay rattle Stock 2006 -2010 Explorers 2
H Resonator Rattle Stock 2006 -2010 Explorers 6
V Dash Rattle Question. Stock 2006 -2010 Explorers 3
S I just started to hear a rattle in the rear gate. Stock 2006 -2010 Explorers 2
S rattle with heat passenger side Stock 2006 -2010 Explorers 2
M Rear Brake Rattle - what to do?H Stock 2006 -2010 Explorers 1
T Engine Rattle Stock 2006 -2010 Explorers 39
S Metalllic dash "rattle" Stock 2006 -2010 Explorers 11
D New Problem - Rattle From Drivetrain Stock 2006 -2010 Explorers 11
M Intermittent Moonroof Rattle While Driving Stock 2006 -2010 Explorers 0
B 06 Steering Wheel Rattle Stock 2006 -2010 Explorers 1
R Liftgate Rattle Stock 2006 -2010 Explorers 20
T bad bearing like noise in front Stock 2006 -2010 Explorers 7
S Strange "whale moaning" type noise from driver's rear area. Stock 2006 -2010 Explorers 4
I Humming or Roaring Noise Gets Louder with Speed Solved Stock 2006 -2010 Explorers 2
M Front Wheel/Axle Noise Stock 2006 -2010 Explorers 5
L Can't find where the noise comes from Stock 2006 -2010 Explorers 2
D Noise from factory headunit Stock 2006 -2010 Explorers 2
P Knocking noise 4.6 3v Stock 2006 -2010 Explorers 11
H 08 mercury mountaineer front end noise Stock 2006 -2010 Explorers 5
M 2010 Mountaineer noise coming from Driver Front Wheel under braking Stock 2006 -2010 Explorers 9
G Strange Noise Stock 2006 -2010 Explorers 2
V Popping noise from front end? Stock 2006 -2010 Explorers 1
J Clink noise from front end Stock 2006 -2010 Explorers 2
K Osilating "thruming" noise in turns. Stock 2006 -2010 Explorers 6
S Noise when Accelerating. Stock 2006 -2010 Explorers 1
S Noise when slowing down Stock 2006 -2010 Explorers 4
J 2006 4.6L V8 XLT whining noise Stock 2006 -2010 Explorers 1
B Rhythmic noise coming from rear driver side Stock 2006 -2010 Explorers 7
S 2006 4.0 Timing Chain Noise? Stock 2006 -2010 Explorers 10
Similar threads
