rattling by heat shield | Ford Explorer - Ford Ranger Forums - Serious Explorations
mrbrinks
BC
1993 Ford explorer
So, I have this rattling noise coming by the heat shield. Only does it when I'm in any gear other than P and N. Just now I have noticed it in the cab. Really irritating and would like to get it fixed. If you guys have any idea to what it would be, I'm all ears.
pkn
Houston, TX
'92 '05 '10 2WDstockXLTs
I had this issue with my 1st gen 92 XLT. Heat shields are spot-welded, some spots gave up and the heatshield rattled. I fixed it with stainless steel hose clamps from Homedepot. You can easily combine clamps to get the length you need to put the clamp around the heat shield.
Having said that... On my wifes '05 XLT I also had rattling coming from the left catalytic converter, right from inside of it. Rattling and trouble code reporting this converter dead. Ended up replacing the whole Y-pipe...
mrbrinks
BC
1993 Ford explorer
Well, if it does seem to be the cat, then I'll just replace the whole thing as I plan to get a flow master muffler soon. If it is the heat shield, then I'll definitely do that! Thanks.
