Rattling Shaking Noise - HELP PLEASE
dsturch1
Pennington, NJ
03 4.0 XLT & 98 5.0 XLT
Alright everyone, any input and or help here would be GREATLY appreciated. I have a 98 Explorer with a 5.0L in it and I have had a noise going on in my truck for a little while and I have had zero luck with anyone at all being able to help me figure out what is going on. When I am driving, the truck will drive just fine - however there will sometimes be a rattling noise coming from the truck. If I have the pedal in the same spot and am cruising, more often on the highway - I will notice a rattling or shaking noise from under the truck.
Initially I thought it was my e-brake cable, so I changed the cable out and nothing changed. I then took my truck to an exhaust shop, they tightened up all of the O2 sensors and checked all of the hangers and nothing was changed. The noise gets worse if I accelerate a little bit more, however if I let off of the pedal completely all together - the noise stops. Any pointers, help, or advise would be greatly appreciated!!!!!!
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
joker1457
Aurora, Co
98 Eddie Bauer 4.0 SOHC
Have you checked the driveshafts for play?
RomeovilleIL
Illinois
98 LTD, 00 XLT
This is a 5.0 right? Is there any vibration in the vehicle to accompany the noise? Does it seem to come from a particular area under the truck?
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
Go underneath and whack the muffler pretty hard with your fist, listen for a rattle.
then hit the cat converter under the transmission. While under there grab the front drive shaft and try to twist it, move it back and forth
edit, our 93 made a buzzing noise only at certain throttle positions, loads. It was the heat shield above the muffler. A couple of self tapping screws fixed it
dr pepper
1999 Explorer
The thing about rattles is that they can be the simplest thing at times. Check the simplest things first . I had a rattle on my s10, ended up being the rubber seal just inside the caliper where it receives the attachment bolts (.50 cents).Take into account the fact that you have to be traveling at a certain speed. Does it happen all the time or intermintently?This rattling could be in combination with out of balance tires causing whatever it is to rattle . Check the rear shocks. On my explorer (99) it has a small shock in the rear that sits sideways, pardon my ignorance but I do not know what its function is, but thats something to check. The heat shield on the tranny was loose on mine and caused a rattle , that was my bad. Anyhow you get the idea . SIMPLE FIRST
S Need Help..replaced hub/bearing still shaking and rattling Stock 1995 - 2001 Explorers 0
G Rattling noise from engine compartment Stock 1995 - 2001 Explorers 48
D My 1997 explorer sound's like a diesel engine rattling. What could be the possible cause? Stock 1995 - 2001 Explorers 4
F 00 Explorer 4.0l Rattling When Cold Stock 1995 - 2001 Explorers 10
J Valve rattling under load in 99 explorer 5.0ltr. Stock 1995 - 2001 Explorers 16
P Advanced Rattling at 3K Stock 1995 - 2001 Explorers 25
B Random cold start/idle rattling Stock 1995 - 2001 Explorers 3
E 1999 Ford Explorer Rattling Sound Stock 1995 - 2001 Explorers 3
2 Front End Rattling Noise Stock 1995 - 2001 Explorers 1
S Rattling from serpentine belt Stock 1995 - 2001 Explorers 2
C Rattling sound coming from steering column.. Stock 1995 - 2001 Explorers 0
no1plantman Still getting a rattling sound Stock 1995 - 2001 Explorers 9
shadowless127 Weird metallic rattling sound Stock 1995 - 2001 Explorers 3
D making weird rattling noise Stock 1995 - 2001 Explorers 12
S Rattling noise only in drive with brake on Stock 1995 - 2001 Explorers 7
P 2000 Explorer needs a fastener for rattling exhaust Stock 1995 - 2001 Explorers 9
M 5.0 Rattling and Burnt Rubber Stock 1995 - 2001 Explorers 3
B Fix rattling noise with timing/cam tensioner, Explorer Stock 1995 - 2001 Explorers 2
R Rattling or Clicking Noise from Front Wheel Stock 1995 - 2001 Explorers 3
S Rattling under the truck Stock 1995 - 2001 Explorers 4
0 Bottom End Rattling Stock 1995 - 2001 Explorers 8
L Uphill Rattling Stock 1995 - 2001 Explorers 5
D Rattling noise from inside the hood Stock 1995 - 2001 Explorers 0
M Rattling front driver side Stock 1995 - 2001 Explorers 8
P Rattling Stock 1995 - 2001 Explorers 0
E LOUD Rattling knock TOP END Stock 1995 - 2001 Explorers 2
M Rattling coming from 4.0 SOHC 2000 Sport Stock 1995 - 2001 Explorers 4
N Quick Question about rattling noise - Need HELP! Stock 1995 - 2001 Explorers 6
I rattling under my explorer Stock 1995 - 2001 Explorers 4
A 02 Sport Rattling Stock 1995 - 2001 Explorers 0
H rattling Stock 1995 - 2001 Explorers 0
G Rattling Windows - drive and passenger Stock 1995 - 2001 Explorers 11
A Rattling Sound coming from Bell Housing Stock 1995 - 2001 Explorers 7
T Rattling noise at 2500+ rpms Stock 1995 - 2001 Explorers 2
D rattling noise near or around engine? Stock 1995 - 2001 Explorers 3
T Can't drive! Loud rattling noise from front end Stock 1995 - 2001 Explorers 4
S Rattling liftgate... Stock 1995 - 2001 Explorers 0
W rattling/clunking when accelerating or when the engine is working harder than normal Stock 1995 - 2001 Explorers 3
R Chain rattling noise Stock 1995 - 2001 Explorers 4
storlied Rattling at high speeds? Stock 1995 - 2001 Explorers 13
R 4.0 OHV vin X rattling like a diesel Stock 1995 - 2001 Explorers 7
I the infamous rattling 98 4.0 OHV Stock 1995 - 2001 Explorers 24
W Rattling/clicking sound from engine bay... Stock 1995 - 2001 Explorers 7
M Rattling at low rpm and high loads, timing chain rattle? Stock 1995 - 2001 Explorers 11
K My clutch is rattling? Please help Stock 1995 - 2001 Explorers 7
R Mysterious Rattling Noise..... Stock 1995 - 2001 Explorers 10
A rattling one second after start up Stock 1995 - 2001 Explorers 7
D Rattling Explorer Stock 1995 - 2001 Explorers 5
L Rattling sound when accelerating and oil pressure indicator going mad, help please… Stock 1995 - 2001 Explorers 6
A Rattling in the steering column Stock 1995 - 2001 Explorers 1
Similar threads
