jackedranger said:
sounds good man...just so you know...i will try to get my truck together decently for a run that weekend...but just so you know what it looks like if i happen to show up on the trail and you are wondering...here it is...minus the brush guard for now...
QUOTE]
What we will do is set up a meeting time so that we all hit the trails together, you have to be in a group of three all the time. I can pm you my number so that you can call me, or if u have a cb, we can use that once u get there. What do you need to do to your truck yet, I could help u wrench over my break.
i go on break from march 5 to the 12, but i need to get my 4x4 squared away right now, i am in the process of gathering parts, it wont be a problem doing it, just getting the money together and getting everything, its probably going to be pretty close, but i will try and pull it off, pretty much all depends on if my income tax refund comes within a week or two, if it does, i will be set for sure, i'll let you know when it gets alittle closer
i basically have to rebuild the front end...i need all the little shi* to fix it and i am in the process of gathering them now...like spindle bearings, seals, splined washers, c-clips, axle shaft u-joints and such...like i said its going to be real close, but i will try my damndest to get it ready
and yeah i have a cb, so if i go, we'll be set, other than that, everything sounds good, is anyone else attending?
