daveg
- July 15, 2003
- Bridgewater MA
- 1994 Explorer
Please someone help….
I own a 94 Explorer 4.0 l with 180,000 on it and have been running into problems with it. Here is some background.
15,000 miles ago this exact same thing happened BUT only in the rain. The truck would run Sooo rich that people wouldn’t travel behind me. It would burn your eyes. Well I replaced the Fuel Regulator but the same thing was occurring. I then changed an 02 on bank 2 and my problem went away…. Wellllll after coming home from Vacation the other day my truck is doing the exact same thing. I decided to replace both 02’s but that did not fix it. (I have not tried resetting my computer yet by disconnecting the battery) At times when I am driving, the truck runs normal for a bit only to act up again. I clean my MAFS and for 2 miles the truck ran great again but then like poo again.
I took some codes from the computer and this is what I have.
177 Heated Exhaust Gas Oxygen sensor voltage signal indicates rich bank 2
181 Heated Exhaust Gas Oxygen sensor voltage signal not switching indicates lean during part throttle engine operation bank 1
186 Injector Pulse Width higher then expected or Mass Air Flow sensor signal voltage is lower then expected.
I know the code 177 to be true because when I removed both 02’s to replace bank 2 (left bank) was black and bank 1 (right ) was whitish.. My gas mileage is about 5 miles to the gallon (no joking)
Does anyone have any Ideas????
Please Help!!!!
-=daveg=-
Please Help!!!!
-=daveg=-
