Fixed, I'm actually embarassed
I've had the intermitant cruise problem ABS occasionally and so on. I've tried everything, switches, recall harness, fluid level, checked servo, and the list goes on..... Took the Sploder in for an oil change and got the super inspection, you know the one where they want to fix everything including things that don't need fixed or changed. Tech comes to the waiting room, with a list of things that amounted to more than she would sell for in this market. All this from wipers to rear axle seals. My response, I came in for an oil change, not an overhaul. He says OK, but you really need new brakes bad, I'd be scared to drive it home they are so bad. After convincing him I was a dare devil he assured me he was right about the brakes and I should get that fixed ASAP. So I pay up head home and get out the jack and pull a wheel....Dang he wasn't kidding, so I gather new pads and rotors and start into it, cake job. Couple hours later done. Low and behold cruise now works flawlessly, and everytime it's applied. Turns out excessive brake wear will prevent cruise from working. As bad as the brakes were, this didn't happen overnight. I'd say about the same amount of time, I had wear that I should have caught a couple three years ago. We have four vehicles, and only two drivers, so this was not driven by me often enough to notice, the real problem....BRAKES AND ROTORS !!!!!!! She's fixed now though. Hope this helps Randy"pear"Bauman
