Re-use a 2015 Mustang key fob for 2017 Explorer | Ford Explorer Forums
RaisinRoy
2017 Explorer Sport
I recently traded my 2015 Mustang GT for a 2017 Explorer Sport and want to use my Mustang Mykey for the Explorer. Can that be done? It looks like I need to de-program my Mustang key first but not sure if that will work either. Any help out there?
Welcome to the Forum.:wave:
I don't have the answer but for some reason I'm thinking something similar was brought up before but I haven' been able to find it. I'm sure that some members will be able to provide you with the help you're looking for. Good luck.
maybe not very PC, but shouldn't the mustang key have stayed with the Mustang???
It's why used cars often come only with one key and no owner manual. Pretty annoying
Obviously, my apologies if you left the 2 keys with the Mustang and the one you are talking about was/is a spare one
Its not going to hurt anything to try it. Just give it a shot.
The one I have is the extra key I bought and programmed it as a Mykey that I paid over $100 for Luc. I did turn in two keys when I made the trade.
I did try to program it to the Explorer. Apparently it needs to be de-programmed from the Mustang before I can program it for the Explorer. It may not work at all since the Mustang was a Sync system and the Explorer is a Sync 3 system.
Do both have remote start on it?
Might have helped if the MyKey setting was cleared using the Mustang before trading it.
might be long shot, a quick search on ebay didn't have any cross over listings so far
Looks like they have the same FCC number
Strattec 5926054 5 Button Ford Proximity Smart Key 2 Way
Insert blade is not included (can be purchased separately K-FD-EM6)
902 MHZ
FCC ID: M3N-A2C31243300
Part: 164-R8117
Strattec 5926056 5 Button Ford Mustang Proximity Smart Key 2 Way, brand new
902 MHZ
Part: 164-R8119
The frequency for the Explorer is 315MHz.
Only for vehicles without remote start. If it has remote start then it is 902mhz. This started in 2016
If I recall correctly, when I checked my VIN on Ford ETIS it showed both frequencies. Could one be for remote start and the other for the locks or just the TPMS?
TPMS operates on 315 regardless of remote start or not.
Here is the 315 mhz no remote start
Strattec 5926057 3 Button Ford Proximity Smart Key 1 Way
315 MHZ
Part: 164-R8111
Strattec 5926063 4 Button Ford Mustang Proximity Smart Key 1 Way
315 MHZ
Part: 164-R8120
902 MHZ
Part: 164-R8117
902 MHZ
Part: 164-R8119
I'm confused now. I don't want to buy one, I want to reprogram the Mykey from my 2015 Mustang GT which is a 5 button with remote..
315 MHZ
Part: 164-R8111
315 MHZ
Part: 164-R8120
I have the same FCC M3N-A2C31243300 number on both the Mustang key fob and the explorer key fob.
