No issues since June 5, 2022 - Now at 226,x.. miles.
December 2023 - O/D Off flashing on a cross-country trip .
Code is TC lock/unlock issue.
While not fatal, having this error is near fatal to me (800 miles from home, and no shop on the homestead).
Nearest shop was a Firestone in Arkansas and they were packed - I told them I had 2 concerns:
Transfer Case Level
5R55E venting high pressure ATF at 80mph in the mountains.
They found everything was OK, but the trans was a "quart+ overfilled" - no one touched it (with my knowledge) and the trans was "between the lines" before our 2,200 mile trip, I had changed the external trans filter (prefilled with fresh MERCON LV as it was all that was available - <1QT), trans fluid level checked warm on flat ground before we left.
They showed me what was going on (ATF from the vent back to the rear bumper on EVERYTHING), and discussed how to remedy (all labor intensive). I said drop the (new) external filter, drain, repeat - since I converted to "Full-Flow" with an external thermostat, the filter fills instantly.
2 drain cycles needed to get back to correct level (Mobil1 M301A), and after hitting a carwash with an "undercarriage" cycle, we were all set.
Venting stopped, but the O/D OFF flashing issue remains, along with the code.
Here are my thoughts (I welcome opinions):
TCC Lockup is hit and miss, at 80+MPH the TC isn't locked, creating excess heat INSIDE the trans (Fluid looks like new, no smell), and that pressure blows out the vent, the remaining fluid is cooled by the MASSIVE external cooler and returned - but the heat (and possibly the 1QT of "Low Viscosity" Fluid) may be causing expansion/aeration of the fluid, making it LOOK like it is overfilled.
That's my theory anyhow.
But I've swapped strategies.
The 5R55E will be babied until I can have an alternate vehicle @100%.
Then:
V8/4R70W/AWD swap timeline gets shifted to the left of the calendar.
Later the AWD to BW4406M swap, once I have all the parts (Swap was going to be everything at once).
5R55E gets gutted/rebuilt, receives extra clutches, new frictions, and a 4R44E bellhousing to go behind a 2.5L (for the Foxbody swap).
