re weights in a a4ld with zc piston???? | Ford Explorer - Ford Ranger Forums - Serious Explorations
fordnut71
oshawa, ontario. home 2 goverment motors canada
99 ex sport
i just picked up a zc piston an cover for my a4ld when i was in the tranny shop the guys says i need a match weight set to use that piston.
well the tranny im putting it into already was rebuilt 3000km ago so i dont know what was used in there. :confused:
so is it still safe to use that piston servo set for my o/d???
still not know what weights are in there
btw iv already rebuilt the valve body with same kits used in the stickys:thumbsup:
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
fordnut71
99 ex sport
well i did put the zc servo in an the truck is up an running again but od dont seem to be working as well now seem to be a slight slip till i let up to shift . when i put the servo an cover on i used the spring for the 5r55 bore i think i need to use the a4ld od spring . the ab servo i used the pink spring from shift kit
