- May 3, 2003
- Smithville/Austin, Tx
- 08' Suzuki SX4
Ok, I may have all the tech books for drivability codes but I have none for ABS codes.
Found out yesterday that I have an ABS light on the dash with the brake lights, for guessing rights I replaced the axle sensor on the diff, and reset the pooter.
Backed out and bam, the lights came on again.
Ran self test on ABS pooter and got a code 16
Could someone tell me what code 16 means, I did a search on here and found a few things but not 100% convenced that the ABS ECM is bad.
I'm a little harder to persway than that, I need more proof, so if anyone has an ABS book and can decipher the code for me it would be greatly appreciated.
1992 Navajo/Explorer 4X4, auto, 4.0 OVH
thanx.
P.S. the lights are on during 2WD and 4WD, so it's not a problem with the switch in the transfercase.
thanx.
