Blown
- December 6, 2007
- 2000 X-Edge
I want to get some air assist for a better ride and to be able to haul stuff level and safe. I have found kits made by Ride Tech or AirLift for Rangers. I get some time this AM to get some measurements and see if they will fit or be adaptable.
I recently removed Monroe air shocks. The Monroe's were pretty stiff as I am running around without a back seat, so there is less weight to support. The Monroe's are adjustable but you are required to keep a minimum 40lbs, in them. I went with KYB Gas Adjust Shocks and got a better ride. Now, I know when I load a couple bikes on a hitch mount and camping gear,,....................it is likely to sag in the back
