Rear Axle Seal question? | Ford Explorer Forums - Serious Explorations
weaver84
04 Ford Explorer XLT
Would a Rear leaking Axle Seal cause the truck to have traction issues when going up my gravel driveway? I haven't check the diff fluid color or level yet.
Traction issues like what?
Sounds most likely as Torque converter slip.
Rear axle seal is non related situation.Seal leaks because of the CV joint bearing runout.thats all
Oh ok, what can I do to check on the torque converter? Haven't checked it fluid yet either.
Several TC check procedures described at factory workshop manual ( cant remember right now sorry about that).
Try to use youtube search as per your car symptoms
7L1Z-4A109-D
Rear axle shaft seal (locking ring included)
Rear axle shaft bearing
F65Z-4B413-A1A
Tools:
Slide hammer and seal/bearing installer
