IAmTodd
4x Explorer Veteran
- April 8, 2002
- Johnstown, PA
- 2015 Jeep
I've done some searching and I can't seem to find a similar situation. The past few days I've noticed some weird braking. It seems as though the rear brakes are locking up on wet pavement. If I'm going slow enough the back wheels will drag, if I'm moving around 10mph the ABS will kick in.
It seems more of an issue on wet pavement for obvious reasons. I had the drums off when I first got the truck and they looked fine. The front brakes are new including calipers, system was flushed and the ABS light is off and as far as I can tell the system is operating as it should.
The only two changes were it getting inspected last week (may call to see if the brakes were adjusted) and it was rear ended on Monday (yay for hitch and steel bumper, no obvious damage).
Anything else to check for?
