rear brakes not working
rsw2008
My 95 EX EB
Location
pine grove ca
pine grove, ca.
91 xlt 95 ex eb
91 xlt 4.0. Rabs light is on all the time, front brakes locking up on hard braking. Was told that a piston was stuck in the bottom of the master cylinder or the rabs unit.there seems to be no braking on the rear axle.
this is only one of many problems with this thing.
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
ricco750
Springfield, MO USA
'93XLT4X2 (3:27 LimSlip)
Do you have a question? It certainly sounds like you need at least a new master cylinder.:usa:
04sd
pa
'05 F150, '84 Ranger
On my '90 Bronco the RABS unit was bad resulting in no fluid making it to the rear. I removed the unit and ran a new line directly to the rear. IMHO the early rear only ABS was garbage and never did work well so just get rid of it. I bought a '92 Ranger new with the RABS and could easily lock up a rear tire on a wet road.
rsw2008
My 95 EX EB
Location
pine grove ca
pine grove, ca.
91 xlt 95 ex eb
rear brake problems
yea i was thinking of eliminating the rabs unit,but iwanted some input from the guru's before i did it. it looks like i can just take it out and install a line in the place of it. ill check the master cyl. just to make sure. living in a motel now, so there's not much i can do here.
thank's guys! will update later!
mcelwajy
Monroe, OH
1993 Eddie Bauer
I just dealt with the stupidity that is the RABS system. There were spider webs in my drums....they weren't doing anything. Upon bleeding them , no pressure at all was going to the rear. Ended up being the RABS hydraulic unit mounted in the frame rail. 115 at O'reilley with a lifetime warranty. SO now they work, but my ABS light is on....wonderful....good luck
