Rear Caliper Piston ?
madman65
Texas
'03 XLT
How do you know what the piston is made of without having the pads off?
Any one have any ideas or info on this?
I looked at O'Reilly and this is what they show for these Wagner pads.
THERMOQUIET 4.0L ENG - w/STEEL PISTON LIMITED LIFETIME WARRANTY
THERMOQUIET 4.0L ENG - w/PHENOLIC PISTON LIMITED LIFETIME WARRANTY
tks,
Brian
Blee1099
Evil Asian
Moderator Emeritus
EF Vendor
Elkridge, MD
The brake pads shouldn't be different.. I just did a search. You need the Bendix MKD881 or equivalent like the Raybestos PGD881
R Rear caliper piston lock-up possible? Stock 2002 - 2005 Explorers 2
R 02 Sport rear caliper piston compression. Stock 2002 - 2005 Explorers 0
T Stuck? Right Rear Caliper Stock 2002 - 2005 Explorers 8
L replacing the rear brake caliper guide bolts and dust boots Stock 2002 - 2005 Explorers 8
L rounded 10mm rear caliper slide bolts Stock 2002 - 2005 Explorers 4
K rear brake caliper bolt size Stock 2002 - 2005 Explorers 1
2 Rear right side caliper stuck? please help Stock 2002 - 2005 Explorers 3
B How to remove rear caliper Stock 2002 - 2005 Explorers 8
T Rear brake caliper question Stock 2002 - 2005 Explorers 1
A Rear Diff Pinion Bearing Stock 2002 - 2005 Explorers 3
T Parasitic draw on battery, not radio/dvd nor rear wiper Stock 2002 - 2005 Explorers 1
MartyD 2004 Center console rear A/C vents Stock 2002 - 2005 Explorers 2
G Rear diff: What is "acting funny"? Stock 2002 - 2005 Explorers 0
G Need to Rent/ borrpw Rear Main Seal Installer 2002 v6 SHOC 4.0 Stock 2002 - 2005 Explorers 5
R Rear end noise Stock 2002 - 2005 Explorers 3
0 Rear Ball Joints 2003 16" Wheels Stock 2002 - 2005 Explorers 4
L Rear main seal Stock 2002 - 2005 Explorers 2
A REAR stabilizer bar ball joint hitting inside of Rim Stock 2002 - 2005 Explorers 2
M rear suspention work, some questions Stock 2002 - 2005 Explorers 0
Number4 Solved Rear driveshaft to flange Stock 2002 - 2005 Explorers 1
LiKuiD 05 Rear Diff Whine vs. 02-04 Stock 2002 - 2005 Explorers 1
M front and rear wheel bearings question Stock 2002 - 2005 Explorers 3
Y Rear A/C Issue, 2005 Explorer Limited Stock 2002 - 2005 Explorers 2
J Rear drivetrain noise (not wheel bearings) Stock 2002 - 2005 Explorers 16
C Rear sensor Stock 2002 - 2005 Explorers 4
L rear hatch applique Stock 2002 - 2005 Explorers 11
B 2002 Explorer Rear Camber Issue Stock 2002 - 2005 Explorers 12
M Completely removing the rear panel appliqué and not putting it back on Stock 2002 - 2005 Explorers 6
L Exteremly confused: Loud grinding and binding coming from passenger rear wheel well Stock 2002 - 2005 Explorers 15
D Rear window hinges (no nipples) Stock 2002 - 2005 Explorers 1
S New rear diff install Stock 2002 - 2005 Explorers 3
L Rear window Stock 2002 - 2005 Explorers 2
L broken small hose on rear end (vent or breather tube???) Stock 2002 - 2005 Explorers 0
C Rear Wiper Motor Issue Stock 2002 - 2005 Explorers 0
M Lessons learned, electrical issues (door ajar, power windows, out side rear view mirrors, power locks) Stock 2002 - 2005 Explorers 2
B 05 XLT rear end problem / Need outside the box solution Stock 2002 - 2005 Explorers 7
P Rear Differential Leak Stock 2002 - 2005 Explorers 9
S Reman rear diff questions/suggestions Stock 2002 - 2005 Explorers 11
W Crack down rear tailgate Stock 2002 - 2005 Explorers 15
P No rear heat Stock 2002 - 2005 Explorers 1
A Rear Heat Stock 2002 - 2005 Explorers 1
S Rear wheel bearings replace and rear diff ????? Stock 2002 - 2005 Explorers 13
T Ordered SKF Rear Wheel Bearing - Received OCPA Made in KOREA?! Stock 2002 - 2005 Explorers 7
A New rear rotor turning blue? Stock 2002 - 2005 Explorers 4
M 4.0 Rear Timing Chain Stock 2002 - 2005 Explorers 2
S Replacing rear sway bar, concerned bolts may break. Then what? Stock 2002 - 2005 Explorers 3
C Rear end fluid Stock 2002 - 2005 Explorers 8
M Rear abs sensor Stock 2002 - 2005 Explorers 5
doug625 Rear hatch Glass 2002 Stock 2002 - 2005 Explorers 0
KA3NXN 2002 Explorer swaying after major work done on the front and rear Stock 2002 - 2005 Explorers 3
Similar threads
