Rear Camera - No Guidelines Show
bluelion
Spring, TX
2012 EX Limited
back up camera 'guide lines' OFF
so i noticed a few days ago that the 'guide lines' in the back up camera were not on the screen. i went into the menu and magically the option was on "off"...so i put it back "on", everything worked fine again.....then this morning, same thing. the guide lines were off again. i went into the menu and sure enough, guide lines were "off"....
how is the option keep turning itself OFF? i have been the only person driving the explorer so i know my wife didn't accidentally turn off the option.
VinceL
Frisco, TX
2013 Explorer Limited
It's the magical world of MFT, where anything can happen....!
FordIVTteam
Official Ford Rep
Dearborn, MI
Ford Explorer
Bluelion,
Are any other settings doing the same thing? Let me know if you notice anything.
Thanks!
Rebecca
bluelion
Spring, TX
2012 EX Limited
at the moment, no other options are doing this. i'll definitely let ya know if something up comes up.
Sully949
2011 Explorer
I have a 2011 Explorer XLT. Storm did some damage to the rear hatch. That was replaced at a body shop along with the rear camera. Now I don't have the rear camera guidelines showing on the screen. I checked the settings and they are set to ON to show guidelines. Any idea why this may be happening? Is it a software issue or does something need to be reset at the dealer? I tried searching in the forum. Thanks for any help.:usa:
Falcor00
Texas
2012 Explorer Limited
Hmmm that is really odd. I'm not sure... but on the same topic.. did your guidelines move when you turned the steering wheel? I thought they did in the vehicle I test drive; but don't in the vehicle I bought!
Sully949
2011 Explorer
No on my XLT I have the fixed guidelines. The ones which look something like bars on the left & right of the screen and are green, yellow, and red. I'm not sure what option package includes the adjusting guidelines or if that only comes with the LTD.
boss377
Annandale, Virginia
2011 Limited
Mine don't move on my LTD. The moving lines are over-rated anyway. The Cayenne has them, and I don't find it a bit of help parking. It still takes a second shot to square the car up. If after a couple of weeks driving the Explorer, you can't back into a space with the camera, you need some remedial training.
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
I have a Limited and have both Active and Fixed lines. According to the manual, for the Active lines there are 3 settings. Active + Fixed, Fixed and OFF. I do find the moving lines to be helpful in some situations.
For the Fixed lines, they can be set to either ON or OFF.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
I love the active lines, when backing into parking spots it is nearly 100% accurate. I believe you have to have the parking assist feature to have the active lines feature.
bluelion
Spring, TX
2012 EX Limited
that's correct.... i have a ltd 301a and have the guidelines but not the active guidelines....
to the OP, so prior to having the hatch repaired, you DID have guidelines? if so, i would take it back to the shop that made the repairs.
i had an issue a couple times that MFT would turn OFF the guidelines by itself and i would have to manually push the ON button in the mornings....but your issue sounds different.
Hidef
2011 Limited
I am not positive, but I believe the moving lines are part of or included with the Park Assist option.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
That is what I just said lol
VinceL
Frisco, TX
Isn't there some sort of registration/calibration that needs to be done? I have a faint recollection of that being discussed some where in this board...
Bohunk
Glen Ellyn, IL
2016 Platinum
No active rear camera guidelines
My guidelines vanished last week, all settings Menu/vehicle/rear camera are set to active+fixed and on and the preview shows what I used to have. Going to dealer for answer. BTW, my friends 2011 LTD also lost the guidelines today. Something vewwy squewwy, around here!:banghead:
NEWPORTNJ
NJ
2020 ST EXPLORER
St, Pk
You dont have to go to dealer its all in the settings if you did a mft reboot or the system it self rebooted then you have to go back into setting and re set it ! It has happen to me twice.
Bohunk
Glen Ellyn, IL
2016 Platinum
Thanx, NJ, but I took out the fuse and waited for 3 minutes, started the vehicle for 3 minutes, then replaced the fuse. Started the Ex and waited until the Sync went through it's process (another 3 minutes on the screen). Reset the camera settings to active+fixed and still no guidelines. I'm stumped!
NEWPORTNJ
NJ
2020 ST EXPLORER
St, Pk
I think thats not the only setting not sure i'm not by my car at this momment but i could be wrong. I really think there is another setting play around with it !
bkmtan
2013 Ford Explorer XLT
I have the exact same problem, autobody shop replaced my liftgate and now the camera has no guidelines after they replaced it as well.
body shop says dealer didn't give any instructions.
is there some configuration that needs the dealer to do? shld this 'extra' work comes from the insurance or from the auto body shop?
peterk9
Staff member
Moderator
Callsign
VE3
Do you get the different coloured warning zones when backing up to an object?
Also it would be very helpful to know which model/year you have since some answers do not apply to all models. If you enter that info in your vehicle specs profile it should show up in the left hand column. That would be very useful info so we can provide the appropriate replies.
B Rear bumper replaced now camera grainy 2011-2016 My Ford Touch / In Vehicle Technology 5
R Rear View Camera when towing 2011-2016 My Ford Touch / In Vehicle Technology 12
V Rear view/back-up camera in 2014 is different from 2008 ? 2011-2016 My Ford Touch / In Vehicle Technology 5
S Adding One Touch to rear windows 2018 Explorer Sport? 2011-2016 My Ford Touch / In Vehicle Technology 4
W No rear hvac controls after APIM replacement 2011-2016 My Ford Touch / In Vehicle Technology 2
J Rear speakers stopped working 2011-2016 My Ford Touch / In Vehicle Technology 2
I Rear Climate Control Question 2011-2016 My Ford Touch / In Vehicle Technology 4
M Rear HVAC function 2011-2016 My Ford Touch / In Vehicle Technology 4
J Rear DVD not working 2011-2016 My Ford Touch / In Vehicle Technology 1
D Rear Air Conditioning - Can I set a temp? 2011-2016 My Ford Touch / In Vehicle Technology 6
J Rear seat DVD system 2011-2016 My Ford Touch / In Vehicle Technology 1
F Rear climate control - always set to "Rear"? 2011-2016 My Ford Touch / In Vehicle Technology 3
T Rear back-up Sensors. 2011-2016 My Ford Touch / In Vehicle Technology 5
C 2013 Explorer Rearview Camera Issue 2011-2016 My Ford Touch / In Vehicle Technology 3
N 2016 Explorer Sport Front Camera Doesn't Work 2011-2016 My Ford Touch / In Vehicle Technology 1
C backup camera diagnose and replace APIM 2011-2016 My Ford Touch / In Vehicle Technology 12
B Radio/Back up Camera stops working 2011-2016 My Ford Touch / In Vehicle Technology 4
C Rearview camera view backwards 2011-2016 My Ford Touch / In Vehicle Technology 3
P Backup camera directional guides 2011-2016 My Ford Touch / In Vehicle Technology 2
K Touch screen intermittently not responsive and backup camera issues 2011-2016 My Ford Touch / In Vehicle Technology 2
M Sync/Phone/Camera Issues 2011-2016 My Ford Touch / In Vehicle Technology 3
C Backup Camera and boat launching 2011-2016 My Ford Touch / In Vehicle Technology 3
G Installing Backup Camera and 8" Screen in my 2013 Explorer - Is it possible? 2011-2016 My Ford Touch / In Vehicle Technology 3
M Front Camera 2011-2016 My Ford Touch / In Vehicle Technology 8
J Adding Back Up Camera - It can be done on the OEM screen 2011-2016 My Ford Touch / In Vehicle Technology 4
C Backup camera alarm 2011-2016 My Ford Touch / In Vehicle Technology 15
D Backup Camera screen cancel button - did it disappear in 3.5.1? 2011-2016 My Ford Touch / In Vehicle Technology 5
F Rearview Camera Active Guidelines 2011-2016 My Ford Touch / In Vehicle Technology 92
K Rearview Camera Problems 2011-2016 My Ford Touch / In Vehicle Technology 591
H V2.7 Backup Camera 2011-2016 My Ford Touch / In Vehicle Technology 20
Similar threads
