Rear Camera - No Guidelines Show
cnsheets
2011 Explemoner
From the MFT screen, click on settings.....then vehicle.......then rear view camera.....make sure the lines are set to on.....It will show you a preview.
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
bkmtan
2013 Ford Explorer XLT
Nope I don't get the coloured warning zones or the lines in the screen, only the pure video feed and the "Check surroundings..." wordings, also the Zoom function is there but doesn't function.
As for the settings, I have tried turning both the Visual Park Assist and Guidelines to On, but still nothing happens.
Googling this issue seems that Ford's F150 has the same issue, not sure if the same SSM 22105 applies
http://www.f150forum.com/f38/disappearing-backup-camera-guidelines-82352/index26/
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
I think it's time for a dealer visit. There appears to be just one camera (19G490) for the Explorer so I don't know where exactly the problem is but the fact that you do not have anything except video definitely indicates there is a problem.
bkmtan
thanks Peter, if I looked at the F150 issue the camera part is also the same 19G490. But they had to do some RCV configuration, according to the SSM. Told the dealer, he had no clue what that means. :( He said maybe take out the battery and try, which he did, to no avail.
Dr Plastic
Newport News, Virginia
'15 Limited FWD
It would not be a camera issue. It only provides the raw image. If your guidelines disappeared then it is a software issue. Did you just recently have your software upgraded?
bkmtan
yeah I would believe so too. I just had my software upgraded to the most recent one with the A4 maps sd card too. Still the same :(
Unfortunately my predicament is like the original starter of this thread. My liftgate was replaced by the auto body shop, so if i go to the dealer, he would tell me to back to the auto body shop as they were the ones who replaced it and thus must fix it.
Anybody knows what RCV configuration means? and is that can only be done by a dealer?
bkmtan
this is what my camera looks like
and this is what the F150 invoice of the guy who had the similar issue
phareous
Charlotte, NC
2013 Ford Explorer Limite
Maybe there is something wrong with the rear parking sensors
bkmtan
guess i'm out of luck here.
ercole
Verona, NJ
2011 Limited
Hi,
I recently had my rear camera replaced (Friday). The original one failed. I too can not get the rear grid lines to turn on, even when I go into settings and manually set it. I confirmed on the left instrumant cluster that the rear camera assist is set to "ON". Still no grids. Camera in clear. Beeping works perfectly (faster as you get closer to the object behind you). Just no lines, grids, or colored blocks as you get closer to the object behind you.
Did you find a solution? Was it a trip back to the dealer?
I did a Master Reset. Nothing.
Ercole
peterk9
Staff member
Moderator
Callsign
VE3
Hi,
Ercole
Did you go through the following procedure?
Active guidelines (if equipped) and fixed guidelines
The active guidelines show the path of intended motion of the vehicle
while reversing. The fixed guidelines assist a driver with backing into a
parking space or aligning with an object behind the vehicle.
To turn this feature on or off when the vehicle is not in R (Reverse), do
the following on the touchscreen:
1. Select Menu
2. Select Vehicle
3. Select Rear View Camera
The fixed guideline options are ON and OFF. The active guideline
options are ACTIVE + FIXED, FIXED and OFF.
• (1) Rear bumper
• (2) Red zone
• (3) Yellow zone
• (4) Green zone
• (5) Active guidelines (if
equipped)
Active guidelines (5) will only be shown with fixed guidelines (2), (3)
and (4).
daborje
South Central Pennsylvania
2012 Explorer
I am having the same problem with my 2012 Ford Explorer Limited with active park assist. Just picked up my Explorer from the body shop last night after replacing a damaged liftgate, including a new camera. Although both active and fixed guidelines are turned on, no guidelines appear in the camera. The body shop called the local Ford dealer who said he didn't know the answer and the dealer was to call Ford for help. The guidelines worked with my damaged liftgate prior to replacement.
Anyone have any further information, yet?
peterk9
Staff member
Moderator
Callsign
VE3
Welcome to the Forum daborje.:wavey:
As Dr Plastic mentioned in his post, I think this is a software issue. It appears that all models have the same camera but they don't all have Active Guidelines. There is also a post about the dealer having to perform a RCV configration but no one seems to know what that means. RCV to me could mean 'Receive'. In that case the system would have to be configured again to receive input from the various sensors throughout the vehicle. That would be something that only the dealer could do.
I'm not sure if this falls under Rebecca or Crystal's area.
If you want some assistance to get 'the ball rolling' on this you can send a private message to Crystal (FordService) using this link;
http://www.explorerforum.com/forums/private.php?do=newpm&u=157968
Include your name, daytime phone number, VIN, mileage, and dealership info in your message.
daborje
2012 Explorer
Thanks Peter! Your help is very much appreciated. I guess the new hardware (camera) has to be synchronized to the vehicle.
sarric
Oklahoma
2011 XLT
I had my reverse camera replaced under warranty on my 2011 XLT last summer. When I got it back it did not have any grids,etc. Come to find out they replaced it with wrong part. Take it back to dealer and make sure they ordered proper camera.
MikeFreas
VA Beach VA
Backup assist quit working
Several weeks ago the backup camera would remain on for quite a while after shifting to drive. Tooke it to the dealer who fixed it by doing a master reset costing me 50 bucks.
a few weeks after that the camera works but the visual overlay (lines and colored blocks) no longer work. The zoom function for trailer hookup does not work either.
I tried to do a master reset from the MFT but it didn't work. I've checked the settings for this feature several times. Trying to avoid another trip to the dealer.
Any ideas?
peterk9
Staff member
Moderator
Callsign
VE3
Any ideas?
I guess the original delay issue wasn't caused by the setting be on delay if you checked the settings. I have mine on delay and it stays that way until I reach 10kmph (6 mph). If the master reset didn't fix the issue you could try a battery disconnect. Leave it disconnected for a while then hook it back up and check the camera again. If the problem is still there, the camera may have to be replaced.
What model do you have? Your profile only says 2012.
daborje
2012 Explorer
Solution Found
I originally posted in January that I was having the same problem with my 2012 Ford Explorer Limited with active park assist. My rear liftgate was damaged and had to be replaced, including a new camera. Upon picking up my Explorer from the body shop, no guidelines would appear on the display screen even though both active and fixed guidelines were turned on in settings. The guidelines worked perfectly with my damaged liftgate prior to replacement.
What I found out: Apparently there were a bunch of replacement cameras manufactured that were either defective or were not appropriately matched for vehicles with park assist. After waiting for several weeks because of backorders due to this manufacturing problem, a new replacement camera was installed and my back up camera with guidelines has worked perfectly ever since.
Although logic suggests it was a software problem, it was not. It was a hardware problem due to a manufacturing problem with the replacement camera.
MikeFreas
VA Beach VA
My car is a Limited.
I'm having the exact same problem as the rest of the folks that have posted in this thread. There has not been any work done on the rear of the car for almost a year. My wife was hit in the rear but the damage was limited to the rear bumper cover. The backup camera worked until a few weeks ago.
I've checked the settings several times. Though I'm not home to look at it currently I don't remember seeing a "rear view camera" option in the vehicle settings. I only remember rear assist.
B Rear bumper replaced now camera grainy 2011-2016 My Ford Touch / In Vehicle Technology 5
R Rear View Camera when towing 2011-2016 My Ford Touch / In Vehicle Technology 12
V Rear view/back-up camera in 2014 is different from 2008 ? 2011-2016 My Ford Touch / In Vehicle Technology 5
S Adding One Touch to rear windows 2018 Explorer Sport? 2011-2016 My Ford Touch / In Vehicle Technology 4
W No rear hvac controls after APIM replacement 2011-2016 My Ford Touch / In Vehicle Technology 2
J Rear speakers stopped working 2011-2016 My Ford Touch / In Vehicle Technology 2
I Rear Climate Control Question 2011-2016 My Ford Touch / In Vehicle Technology 4
M Rear HVAC function 2011-2016 My Ford Touch / In Vehicle Technology 4
J Rear DVD not working 2011-2016 My Ford Touch / In Vehicle Technology 1
D Rear Air Conditioning - Can I set a temp? 2011-2016 My Ford Touch / In Vehicle Technology 6
J Rear seat DVD system 2011-2016 My Ford Touch / In Vehicle Technology 1
F Rear climate control - always set to "Rear"? 2011-2016 My Ford Touch / In Vehicle Technology 3
T Rear back-up Sensors. 2011-2016 My Ford Touch / In Vehicle Technology 5
C 2013 Explorer Rearview Camera Issue 2011-2016 My Ford Touch / In Vehicle Technology 3
N 2016 Explorer Sport Front Camera Doesn't Work 2011-2016 My Ford Touch / In Vehicle Technology 1
C backup camera diagnose and replace APIM 2011-2016 My Ford Touch / In Vehicle Technology 12
B Radio/Back up Camera stops working 2011-2016 My Ford Touch / In Vehicle Technology 4
C Rearview camera view backwards 2011-2016 My Ford Touch / In Vehicle Technology 3
P Backup camera directional guides 2011-2016 My Ford Touch / In Vehicle Technology 2
K Touch screen intermittently not responsive and backup camera issues 2011-2016 My Ford Touch / In Vehicle Technology 2
M Sync/Phone/Camera Issues 2011-2016 My Ford Touch / In Vehicle Technology 3
C Backup Camera and boat launching 2011-2016 My Ford Touch / In Vehicle Technology 3
G Installing Backup Camera and 8" Screen in my 2013 Explorer - Is it possible? 2011-2016 My Ford Touch / In Vehicle Technology 3
M Front Camera 2011-2016 My Ford Touch / In Vehicle Technology 8
J Adding Back Up Camera - It can be done on the OEM screen 2011-2016 My Ford Touch / In Vehicle Technology 4
C Backup camera alarm 2011-2016 My Ford Touch / In Vehicle Technology 15
D Backup Camera screen cancel button - did it disappear in 3.5.1? 2011-2016 My Ford Touch / In Vehicle Technology 5
F Rearview Camera Active Guidelines 2011-2016 My Ford Touch / In Vehicle Technology 92
K Rearview Camera Problems 2011-2016 My Ford Touch / In Vehicle Technology 585
H V2.7 Backup Camera 2011-2016 My Ford Touch / In Vehicle Technology 20
Similar threads
