shane10
- February 9, 2016
- MW
- 2002 Explorer XLS
4WD
Hi all, just finished up changing out all 4 calipers/brakes/pads, original calipers had nearly 240k on them and were showing some wear.
While I was in the rear I also noticed some pretty significant wear on the upper and lower control arms, I've decided I will swap out the entire UCA unit as they aren't ridiculously expensive and to keep things simple. The rear LCAs are nearly impossible to find and $400+ per side.
I'm planning on removing the LCA entirely and taking it to a shop to get new bushings pressed in, however am a bit confused on which parts to buy.
On rock auto under control arm bushing, the rear lower forward and rear lower rearward bushings are pretty obvious, the confusion comes to the bushing (balljoint?) that connects to the knuckle.
I am seeing rear lower w/ cross axis bushing - More Information for MEVOTECH MK80010
And, rear lower outer balljoint - More Information for DORMAN 531804
Not sure which is the correct part, they both look pretty similar in the pictures.
Can't find much info on here about the rear control arms in general, any info is appreciated
Thanks!
Thanks!
