C420sailor
- July 29, 2008
- Long Island, NY
- 98 XLT SOHC, 99 EB 5.0L
My original 8.8 rear (3.55 gears, open diff) has given me nearly 330,000mi of trouble free service. She's starting to get pretty hot on longer drives, and that hot oil is making its way out via the pinion seal (which I've recently replaced...still leaks...). Drained the oil recently to see that she's also starting to make some metal. 5,000mi old oil is grey/silvery with light use. She's earned a rebuild.
I've never done a car/truck diff, only helped a buddy do one years ago (I held the flashlight and passed tools mainly) but I've done a handful of motorcycle final drives so I get the basics.
Anyway, I'd like to order the parts now to have them on hand and I was hoping guys who have BTDT can advise me on anything I may be missing, and especially on any special tools I'll be needing.
In my rockauto cart I have:
-SKF master rebuild kit (pinion/differential bearings and races, pinion and diff shims, ring gear bolts, crush sleeve, pinion nut and seal)
-Differential carrier rebuild kit (four gears, cross shaft, bolt, thrust washers)
-Pinion yoke (old one is grooved from the pinion seal)
What am I missing?
I plan to buy a set of Ford OEM gears, and I very recently (within 5k miles) did the axle shafts, bearings, and seals---so they should still be good, I'll check and clean.
I have a dial gauge setup for measuring gear backlash, 1/4" beam torque wrench for setting pinion torque, gear marking compound. Any other special tools I'll need? Especially with regard to installing pinion bearings and setting pinion depth...
Appreciate this, guys. I hate digging into a job only to realize I forgot parts and/or special tools.
What am I missing?
