glfredrick
- January 25, 2003
- Louisville, Kentucky
- 86-98 Ranger STX
Note that if you are opening the brake lines to do a swap, you should bleed the entire system. All it takes is for an air bubble to work its way into the system to have very weak brakes. By now, the brake fluid is due for a change anyway, as it attracts water and creates bigger problems (like weak brakes).
Bleeding (and bench bleeding a MC) isn't that difficult. You just fill it with fluid, put a couple short stubs of hose from the fittings back into the cylinder and slowly stroke the piston in and out about 10 times. That's standard for any MC work.
Bleeding the rest of the system is also a no-brainer. Just do the rear (tire farthest away from the MC) first, then the other side rear, then the passenger front, and finally the driver's front. It only takes a couple of minutes, and you'll pump out all the old brake fluid in the process.
Not sure why people are so frightened about bleeding brakes that they avoid it at any cost, but that is about half of what makes a brake job a good and successful job versus a death trap!
Good article here:
http://www.popularmechanics.com/automotive/how_to/4213448.html
Good article here:
