rear end.
toughguy
South Florida.
2ford explorers 1999 2000
trying to find out what rear end is in my truck, 2000 ford explorer EB rwd, towing package. changing out fluid and need to know if this is a Limited Slip Differential or a regular one.. thanks.
Genuine Ford Fluid XL-3 Friction Modifier Additive.
1998Exp
Seattle WA
98 Limited V8 AWD
Assuming it's the original one, you can go by the axle code on the door label. Limited Slip will be a D followed by a digit. Open diffs have two digits. If you suspect that it's not the original one, crawl underneath and read the code on the metal tag attached to the diff.
trying to find out what rear end is in my truck, 2000 ford explorer rwd, towing package. changing out fluid and need to know if this is a Limited Slip Differential or a regular one.. thanks.
toughguy
South Florida.
toughguy
South Florida.
Awesome !!! found it !!!! Rear Axle Limited Slip Differential !!!!!
thanks again !!!
