geosnooker2000
- March 29, 2007
- Somerville TN
- '10 Eddie Bauer V8 4x4
My gate handle has been like this for several years. It won't open the lift gate. It will only open the glass. I opened it up and I see the problem. The black plastic shaft sticking out of the handle control apparatus LOOKS like it was broken off and is only long enough now to make contact with the window latch, but not the gate latch.
SOOO I was at the local U-Pull-It the other day and, on a whim, decided to test a 1st gen I was walking by. That handle worked both the gate and the glass. So I grabbed my wrench and pulled that part and felt oh, so, smart.
This evening I was about to just trade them out, and held the replacement up to the one still in the truck. The black plastic shafts look identical in length.
Is it possible (probable) that the steel bracket that holds the glass and gate latches has warped/bent inward away from the black door handle actuator shaft that it is now out of reach to the gate latch? I'm thinking of removing the bracket and bending out a bit and re-installing it.
What do y'all think? Has this happened to any of you?
