RandomNerd2000
- March 26, 2015
- South Carolina
- 00 5.0, 01 4.0.
So, I bought a 2001 Eddie Bauer in June, 4.0, and the hatch didn't open from the outside, to open it, you opened the glass, reached behind a broken panel, and worked the assembly to open it, and generally, it was simple to open, Well, I got a panel from the junkyard, and took the clip from the hatch on my 99, and took the busted one off, only to discover the arm going to the outside handle wasn't connected, and the actuator said May of 2007, so I connected it, now we have the issue. The power door lock inside the hatch didn't work, but if you unlock the glass, after 5 or 6 pulls of the handle with steady pressure on the hatch, it'll open, the handle feels very loose, like it's always locked, but when you unlock the glass, the actuator visibly unlocks, I watched it all with the panel off. Any ideas? I'm somewhat at a loss, I lubed all the linkages and it seemed to help some, but it's far from right, and it's a PITA to deal with.
