fj328
- June 13, 2006
- Algonquin, IL
- 97 XTL
I have searched the forums and have not found any post that exactly fits my issue, hoping someone could pinpoint it for me. My rear passenger door lock will not work properly. I took apart the door panel and checked the lever as well as the latch and both seem to work fine when using the exterior door handle. The actuator does work properly and provides the full range of motion to lock/unlock the door except for when the inside handle is used. Once I pull on the interior handle the lock will not move more than 1/4 inch up/down manually or via the actuator until I pull the exterior handle. When the exterior handle is pulled after this condition I can hear a click and then the lock will move properly again. If the door is unlocked the interior handle will work fine and open the door, as long as the door was not locked after it was closed. All moving parts have been throughly cleaned of dirt and sprayed with WD-40.
