00GT
- January 30, 2003
- Houston, TX
- 07 EB V8 4x4 & 99 EB AWD
Hi all,
I'm trying to fix the e-brakes on my 99 Eddie Bauer V8 All Wheel Drive. I've read dozens of threads here, and it seems like stuck rotors are fairly common. So far I've sprayed about a half can of PB Baster, hit the rotors with a rubber mallot, a piece of 2x4 and a 3 pound hammer, pounded on the hub, heated the rotors (until warm enough you can't touch them) with a propane torch, and then pounded some more.
The rotors are just stuck. I was thinking the ebrake pads were what was keeping the rotors from coming loose but I removed the cable, then turned the star loosening the pads all the way out. Still the rotors won't budge. I'm pretty sure the rotors are just rusted to the hubs. Although I'm in Texas, the first 8 years this truck was in the North East (Delaware).
Any advice on a next step? I'm debating pulling the four bolts on the back of the axle (See photos) I'm guess at that point the rotor and axle will come out in one piece? At that point can I take them to a shop and have them put in a press to pop them apart?
I'm trying to get this apart without damaging the rotors as they look like they are in good shape.
Thanks in advance for any advice.
