FordLover
- March 5, 2001
- Houston, Tx
- '02 XLT
I noticed my entire rear bar was loose, from the end links, and both frame to bar bushings were toast. No parts house could find the bushings listed, so I ended up at the dealership. I got the new Moog endlinks online.
For what it's worth it a pretty easy job, though access is very limited. The nuts on the body to bar are 15 mm, and are on the top side of the frame. I jacked up the rear, put the frame on jack stands, let the rear suspension droop, and removed the rear wheels for better access.
The valuable info is the part number, 3L2Z-5493-CA Insulator
Ford only listed 1 part for the bushing, so all 2002's must have had the same size bar, which surprised me because mine is a V8 and has the heavy tow package. But the part fit perfectly.
I used Moog K80033 end link kit for the rear end links, and did the whole job in about an hour.
