Paulski46
- November 6, 2015
Hello,
I have a 8.8 rear end out of an 95 explorer that I am using on an old truck project. The problem I am encountering is the end links on the rear sway bar not being parallel. I need to make custom frame mounts for the end links and I noticed that the end link on the passenger side is about an inch higher, so I took the sway bar off and laid it flat and sure enough the two ends are not at the same height. Is this normal or did I get a bent sway bar?
Thanks
Thanks
