ieee_raider
- May 22, 2013
- Paris, TX
- 2013 Ford Explorer Sport
I decided it was a little dark when loading anything in the back at night. I decided to add a bit of lighting. Of course I wanted it to turn on and off when the tailgate is opened.
Here are my parts:
1. Identify ideal lamp location, you can move it around a bit to get desired light angle.
2. Pull off trim around upper edges of tailgate.
3. Remove handle from tailgate (pop trim off then nut driver)
4. Pull main panel down, popping loose most connectors, but leave some connected so the panel kind of hangs. Makes working easier.
5. Drill small hole for lamp wiring.
6. Run wiring through hole and screw lamp into place.
7. Pop down headliner. This part is kind of crazy, it's actually held in place by magnets!
8. Run 2 wires (+12V, Common) from lamp up and around tailgate trim.
9. Run the wires through the gromet at the top of the tailgate. It's tough, but if you pop them loose first, you can get the wires in.
10. Pull trim off on back pillar
11. Pull trim loose on driver side rear panel. Don't try to take it all the way off, just loose enough to work behind it.
12. (Optional) Install Normally closed switch to turn lamp off if you want to leave gate open but turn light off.
13. Run common wire straight to aux power port.
14. Run power wire from aux power port over towards center of tailgate (run through switch if desired)
15. Run power wire from lamp down towards center of tailgate
Find good location to install reed switch and magnet. The magnet will go in the hatch, the reed switch will go in the tailgate area.
16. Drill holes and install switch and magnet (this is the scary part)
17. Connect power wire from aux port and power wire to lamp to red and white wires on the switch.
I know it's not the most detailed instructions, but I'd be glad to answer any questions.
Here are my parts:
- GE Interlogix 1076C-N (ebay)
- Optronics BUL-78CB - 6.5" White LED Lamp
- Normally Closed switch (optional)
