2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
balancer bolt & flexplate
Have you loosened the balancer retaining bolt yet? If not, you may want to use the flexplate, a chain and some bolts and washers to keep the crank from turning when you loosen the balancer bolt. If you already have the balancer bolt loose then the flexplate has to come off before you can mount the block on the engine stand.
This photo is how I removed the flexplate bolts. The same method works for the balancer bolt.
