Rear upper control arm replacement bushing | Ford Explorer Forums - Serious Explorations
Philippe_T
NB
2012 Ford Explorer Ltd
The repair shop told me that I need to replace the rear upper control arm on both side because the square bushing is worned.
I checked around and the bushing cannot be ordered. So its about 700 CAD$ each side.
Any idear if this can be ordered online?
Thanks
From the description I'm a bit confuse. Is it with pre installed bushing?
I'm not sure. I was going based on what you said in your first post.
No bushing available so need to replace control arm. If it requires a control arm because the bushing isn't separate, then I'd think it is installed.
