Fred93
- June 13, 2019
- 1993 Explorer XLT 4WD
'93 XLT 4WD makes a 'thunk' in the right rear wheel when turning left. Tried the jack up the wheel, pull on one side of the tire while pushing on the other to test the bearings. Did not notice any wobble from that. However, if I pull straight out (along the axle line) and push straight in there's movement of maybe 1/16 inch or a bit more. Pulled off the brake drum and can see a silver line appear in the hub area when pulled out. Other wheels are solid with the same tests.
Is this from a bad wheel bearing, or is something else going on? Any suggestions on how to fix it?
Thanks very much for sharing your wisdom.
-Fred93
-Fred93
