sullen
- February 28, 2019
- 04 ford
So I need to do my rear wheel bearing and I’m a little confused......
I have (what may be a stupid) question.
I’m seeing how-to’s on replacing the rear wheel bearings including draining the rear diff, and removing the spider gears.
Then seeing some videos on the procedure where there is no mention of this, and the hub assembly is just removed.
I’ve never done the rears, recently done the fronts. Planning on getting and replacing the whole hub assembly, not pulling and just replacing the bearings.
So do I need to drain and pull gears?
Or just remove the hub assembly???
