mbrando1994
- May 17, 2015
- 2003 Ford Ex XLT
4.0 V6
Hey everyone, amidst all the other issues I've been having this month on my Explorer, one of the rear window hinges decided to break off leaving the glass panel dangling on one side, it made for a very interesting removal process fighting with the lifters and trying to avoid breaking the glass. So I ordered the replacement hinges at a cost of $70+ and attempted to install them. Even with tightening them down real good the glass is still able to shift and move around when opening and closing. With the lifters installed it pushed the panel down so far that it won't even close as it makes contact with the liftgate.
It appears the issue may be in the absence of the plastic washers that fit in between the torx bolt and the glass. The originals were corroded and broken in two. Right now I managed to install the glass but can't use it as it takes a lot of effort to line it up properly so it closes tight. It's not going anywhere but seems really sketchy since the glass is able to shift around. Is it the plastic washers or something else I'm missing? The issue is the torx bolts to the hinges, not the hinges to the body. The new hinges also don't sit flush against the glass like the old ones do.
Note: The recall/repair at the dealership was already performed on this Explorer by the previous owner, so no luck there either.
Thanks for any help
Thanks for any help
