  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
Rear window hinges
dr fildo
1999 Mercury Mounaineer
How difficult is it to get to the rear window hinges? Mine are loose and the window is shifted to the left. I can open it and straighten it out, but after a day, it shifts over again. They just need to be tightened.
koda2000
x
If you pop off the top of the interior trim around the top of the hatch, you'll see 2 rubber plugs. Remove the plugs and look into the hatch and you'll see a 10MM nut on a stud. Center the glass in its opening and tighten the nuts and it should stop the glass from moving left/right. Just don't go crazy on the nuts or you could pull the stud out of the back of the hinge.
There are plenty of used Gen II hinges on eBay (link below) and a few NOS ones there too.
2000 explorer rear window hindges in eBay Motors | eBay
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
There are also different hinges that can work, that are from the later Sport models, 2002 and 03 I believe. I haven't searched for any of them, but some may be cheaper. Good hunting.
Alex from GA
'99 Explorer
Thanks koda. I just got through doing mine and BTW the top ones are T27. They were loose too.
P Replacing rear window hinges, questions Stock 1995 - 2001 Explorers 2
T Rear window hinges Stock 1995 - 2001 Explorers 4
M Rear window hinges are bad Stock 1995 - 2001 Explorers 2
inkjunkie Rear window hinges.... Stock 1995 - 2001 Explorers 8
B 1999 explorer rear window Stock 1995 - 2001 Explorers 1
B Rear Window Hinge issues Stock 1995 - 2001 Explorers 7
A Rear window. Stock 1995 - 2001 Explorers 8
B Passenger rear window no power down Stock 1995 - 2001 Explorers 6
W Rubber Stoppers for Rear Window Stock 1995 - 2001 Explorers 1
V Rear hatch window removal Stock 1995 - 2001 Explorers 2
B 2000 Explorer rear window defroster Stock 1995 - 2001 Explorers 3
F Remove intact rear quarter window glass (nonmoveable) Stock 1995 - 2001 Explorers 22
Q Can't open rear window on 99 Eddie Bauer Explorer.... Stock 1995 - 2001 Explorers 11
R Rear window lift supports Stock 1995 - 2001 Explorers 6
M Rear power window issue Stock 1995 - 2001 Explorers 6
F Rear Quarter Window Torque Specifications? Stock 1995 - 2001 Explorers 9
koda2000 Rear side window center track question Stock 1995 - 2001 Explorers 0
D Rear Door Window Pillar Rust Stock 1995 - 2001 Explorers 4
T Rear window wiper Stock 1995 - 2001 Explorers 0
B rear window question Stock 1995 - 2001 Explorers 5
M Rear Hatch/Window Problem Stock 1995 - 2001 Explorers 9
A Rear lift window strut brackets Stock 1995 - 2001 Explorers 11
J 95 Explorer Tailgate/rear window won't open Stock 1995 - 2001 Explorers 2
9 Rear Window Struts Stock 1995 - 2001 Explorers 6
B 1998 Explorer Sport Rear Hatch Window Weatherstrip Stock 1995 - 2001 Explorers 4
D 2001 Ford Explorer Sport Rear Window Does not Latch Stock 1995 - 2001 Explorers 2
M 2000 Explorer, Rear Window Wiper Actuator switch Stock 1995 - 2001 Explorers 5
Swinson1974 Rear window vent visor Stock 1995 - 2001 Explorers 1
koda2000 Leaky Rear Side Window Fix Stock 1995 - 2001 Explorers 0
S Rear wiper not wiping the whole window Stock 1995 - 2001 Explorers 3
W Rear Window Wiper Problem!? Stock 1995 - 2001 Explorers 5
B Driver Side Rear Window Issue Stock 1995 - 2001 Explorers 1
D rear window support are these the same? Stock 1995 - 2001 Explorers 9
D rear window intermitently stope working Stock 1995 - 2001 Explorers 1
D rear window wiper Stock 1995 - 2001 Explorers 3
R 95 Explorer Rear passenger window stuck Stock 1995 - 2001 Explorers 1
L Rear window rust remover? Stock 1995 - 2001 Explorers 4
N Passenger Rear Window Stock 1995 - 2001 Explorers 2
kythri '99 XLT - Rear Wiper rotated all the way past the window and down to the lic. plate Stock 1995 - 2001 Explorers 0
B Rear window sprayer help!!!!!! Stock 1995 - 2001 Explorers 1
M Rear Passenger window and 1 door lock Stock 1995 - 2001 Explorers 4
H Rear window washer reservior 2000 sport Stock 1995 - 2001 Explorers 1
S rear window hatch issue Stock 1995 - 2001 Explorers 3
M Has anyone ever replaced the rear window trim? Stock 1995 - 2001 Explorers 0
H Rear window with defogger Stock 1995 - 2001 Explorers 2
E Rear Defrost Window Glass Connector Stock 1995 - 2001 Explorers 5
T 1996 Explorer rear window wiper grommet Stock 1995 - 2001 Explorers 2
C rear hatch window now opens easy Stock 1995 - 2001 Explorers 0
A 1995 Explorer XLT. My rear driver's side window isn't moving. Stock 1995 - 2001 Explorers 4
K Help! Rear Window Regulator Stock 1995 - 2001 Explorers 0
Similar threads
